LabWindows/CVI
Audio recording LabWindows/CVI
Hi all,
is it possible to record audio/video in cvi?
i understaned that it is require acsses to the drivers of my laptop.
is it even possible?
if it dose, will it work in other computers as well? or only the ones with the same drivers?
(6,833 Views)
If you are able to do it in C you should be able to do it in CVI
(6,805 Views)
My question is actually if i can throw cvi, by ActiveX maby,to operate my cam and take a picture?
(6,802 Views)
CVI does allow access to ActiveX controls. If you are able to accomplish your task through ActiveX you should be able to do so in CVI as well.
Here is some documentation on using ActiveX in CVI:
Programming with ActiveX Controls
ActiveX Control Overview
What ActiveX Features Does LabWindows/CVI Support?
(6,783 Views)
I founed an ActiveX called "camera capture ActiveX" but i can't understand how to work with it.
I don't have much expirence in ActiveX programing.
can somone help me understend how to work with it?
(6,753 Views)
ActiveX was developed by Microsoft; you may have better luck receiving instruction on a forum that is more related to ActiveX. Here are some links that might help you get started:
MSDN Introduction to ActiveX Controls
tek-tips Microsoft: ActiveX Forum
Also don't forget about the links I listed previously about using ActiveX in LabWindows/CVI
(6,728 Views)
