LabWindows/CVI
Autogenerate Documentation Tags
Does anybody know of a way to autogenerate all of the boilerplate code for function documentation tags?  VS2008 has a feature that automatically inserts everything you need (ie function name, parameter names, return values) based on the function prototype just by typing "///" on the line before the function then you just fill in the blanks .  This would save so much time in CVI if I could do the same thing.  The macro feature of CVI doesn't take into account the number of parameters or parameter names so I don't think that is the solution.  Plus I don't even see shortcut keys for directly running a particular macro so it would still be slow in comparison.
(2,979 Views)
LabWindows/CVI does not have this functionality built into the programming environment. A complete List of the Developing and Editing Source Code capabilities that are available can be found in the LabWindows/CVI Help under the Using LabWindows/CVI »Writing Source Code section. I will create a product suggestion for this feature to be added to the LabWindows/CVI development environment.
-Adri K
Adri Kruger
LabVIEW Product Marketing
(2,955 Views)
