LabWindows/CVI
Automatically convert a .tui file to a .uir file
I would like to know how to convert automatically (or with code) .tui files to .uir files.
I know it's possible by using the CVI "Options > Load from text format" tool but I have
to do that a lot of times. So i'm looking for an automated way of doing that.
Thanks for any help you can give me!
(4,081 Views)
I never attempted to do such a thing, but CVI can be operated from external applications (even from another instance of CVI!) via ActiveX. You can find some examples in samples\activex\cvi folder.
The projects listed in this folder use the LabWindows/CVI Server (cvisrvr.fp) that publishes the function CVI_AppConvertTUIToUIR that should do exactly what you are looking for. Given this, you could develop a small application that lists all TUI files in a folder and converts them to UIR format. Anyway, it must be said that fiddling with ActiveX is not the simplest task of all...
(4,075 Views)
Thanks a lot for your answer, it's work perfectly Smiley Very Happy !
(4,071 Views)
