LabWindows/CVI
Automatically load files
Hello, is there a way to load files (which are in a given folder) in a listbox automatically at startup of my program?
And perhaps can also delete automatically the contents of that folder when you exit the program?
Message 1 of 8
(4,976 Views)
You can use the functions GetFirstFile and GetNextFile to obtain all files with a given search path. The file names can then be inserted into a listbox using InsertListItem.
Message 2 of 8
(4,966 Views)
I'll try and let you know.
thank you very much
regards
Message 3 of 8
(4,961 Views)
Wolfgang Sorry, but I can not make it work. The files that are in the folder C: \ TEST all have the same extension (*. dxf), but I don't know their full name ... the program should recognize their name and add them in the listbox (using their own name).
Message 4 of 8
(4,959 Views)
Accepted by topic author ViperNaples
Hello ViperNaples,
this example should be what you are looking for; it is more complete than what you have described, as it scans also for subdirectories and lists their content also.
Message 5 of 8
(4,952 Views)
How did you use the functions?
For example, GetFirstFile ( "*.dxf", 1, 1, 1, 1, 1, 1, fileName ); returns the first file name matching your search critereon in fileName.
Message 6 of 8
(4,949 Views)
Grazie Roberto, darò un'occhiata all'esempio. I tuoi consigli sono sempre utilissimi Smiley Wink
Message 7 of 8
(4,942 Views)
Wolfgang, i use the function in this way:
GetFirstFile ("c:\\TEST", 1, 0, 0, 0, 0, 0, nameFile);
Message 8 of 8
(4,941 Views)
