LabWindows/CVI
BUS Statistic from MAX in LabWindows
In the MAX it is possible to look at the BUS Statistic. There I can see the Error Frames.
Now I want to have the possibility that I can see the Error Frames also in the program which I build with LabWindows.
Is that possible? I am using NI USB- 8473!
(3,151 Views)
You are probably talking about NI IO-Trace former NI Spy. This program redirects Driver calls to itsself when running and forewards them to the driver afterwards. This is for logging.
You are able to catch the errors the VISA driver retuns in case something goes wrong, but i would not call that bus statistcs.
please specify this in more detail. Show me what tool you are using (if not NI IO-Trace) and what Data you mean with Bus statistics (i would associate trafic load or so with "bus statistic" but thats not shown in NI IO-Trace)
(3,121 Views)
