LabWindows/CVI
Background colour is not updated
Hi. I have a curious problem that I do not understand, and perhaps someone could offer an answer.
I'm running some code to log data from an instrument, and when the instrument is not "connected", i.e. state == FALSE, I want to show this by setting a dark background ("BL_OFF") in 4 numeric displays. When it is "connected", i.e. state == TRUE, the background should change to a nice bright colour ("BL_ON").
This is the code that does that:
    if(state == TRUE) {
        SetCtrlAttribute (panel, HV_PANEL_VOLTAGE, ATTR_TEXT_BGCOLOR, BL_ON);      /* Numeric control */
        SetCtrlAttribute (panel, HV_PANEL_POWER, ATTR_TEXT_BGCOLOR, BL_ON);
        SetCtrlAttribute (panel, HV_PANEL_FILAMENT_CURRENT, ATTR_TEXT_BGCOLOR, BL_ON);
        SetCtrlAttribute (panel, HV_PANEL_BEAM_CURRENT, ATTR_TEXT_BGCOLOR, BL_ON);
        GetCtrlAttribute (panel, HV_PANEL_BEAM_CURRENT, ATTR_TEXT_BGCOLOR, &colour);
    else {
        SetCtrlAttribute (panel, HV_PANEL_VOLTAGE, ATTR_TEXT_BGCOLOR, BL_OFF);
        SetCtrlAttribute (panel, HV_PANEL_POWER, ATTR_TEXT_BGCOLOR, BL_OFF);
        SetCtrlAttribute (panel, HV_PANEL_FILAMENT_CURRENT, ATTR_TEXT_BGCOLOR, BL_OFF);
        SetCtrlAttribute (panel, HV_PANEL_BEAM_CURRENT, ATTR_TEXT_BGCOLOR, BL_OFF);
        SetCtrlVal (panel, HV_PANEL_XRAY_ON_LED, OFF);                /* LED */
        SetCtrlVal (panel,  HV_PANEL_STAND_BY, OFF);                      /* LED */
        SetCtrlVal (panel,  HV_PANEL_INTERLOCK_OPEN, OFF);        /* LED */
        SetCtrlVal (panel,  HV_PANEL_INTERLOCK_CLOSED, OFF);   /* LED */
Now to the funny business... If all is well when the program is started, it will run through the "state == TRUE" bit and set the colours to "BL_ON". I know this works as one panel is default set to "BL_OFF" in the .UIR file, but it is changed to "BL_ON" when the program executes. If I then force the program to go through the "else" bit, the colours change to "BL_OFF", as expected. Then when I send the program through the "state == TRUE" code again, one would expect that the colours would change to "BL_ON" (since it says so Smiley Tongue) as it did the first time... but not so! The colours remain dark ("BL_OFF") in the display. The really interesting bit is that the last command in the "state == TRUE" block reads the background colour, and it reads it as "BL_ON" and yet it displays "BL_OFF"! If I then force the program through the "state == TRUE" again, the colours will change as I would have expected them to do the first time through.
Any suggestions?
Cheers,
Mattias
Ps. using LabWindows\CVI 8.0.1
(3,239 Views)
Depending on the rest of your code, you might want to add a ProcessDrawEvents() call, to force any UIR changes made within a program loop (especially from using SetCtrlAttribute(), which has a deferred effect anyway) to actually appear on the screen. Having said that, I have in the past noticed odd things happening with regard to re-colouring screen areas of Windows programs, not just CVI ones. I would hazard a guess that Windows only performs this at a fairly low priority, so on occasion it appears that the expected colours take a bit of time to actually appear.
JR
(3,226 Views)
Thank you for that tip. I had been looking for some function to force a re-draw or update of the panel, but I didn't know of that one.
Thanks for the help!
Mattias
(3,203 Views)
