LabWindows/CVI
Backlslashes in the IDE
Here's a little something that everyone should watch out for.  If you put a backslash at the end of a C++ style comment the compiler will consider the next line as part of the comment and will ignore it.  I believe this is perfectly valid behavior, but CVI's syntax highlighting doesn't show that line as being part of the comment so this can lead to some non-obvious bugs where lines of code appear to be "skipped over" in the debugger.
Here's a screenshot of some sample code in CVI.  Note that in this example the line b = 2 will not be compiled:
Here's the same code copied into Notepad++ with its syntax highlighting:
(3,752 Views)
Hi tstanley,
As you mentioned in the first part of your comment, this is expected behavior.  If you put a line continuation symbol \ at the end of a line, it effectively merges the two lines together. If you have a // comment block in the first line, that effectively causes the entire second line to also be part of the comment.  If you add any character after the \ symbol, it will no longer act as a line continuation symbol, and you won't have this problem.
Alternatively, you can use the /*Comment\ */ comment structure, and this error will not occur.
I hope this clears things up.
Warm Regards,
Daniel Dorroh
(3,734 Views)
I wouldn't normally end a comment on a backslash like that, but I did it by accident - with the backslash key next to the ENTER key it's all too easy to fat-finger it.  Since CVI's syntax highlighter doesn't show the next line as a comment in this case it left me with a real head-scratcher until I realized what was going on.  A search of the project revealed one other place where that had happened, though luckily the resulting bug was minor.  It's just something to watch out for.
(3,726 Views)
Hi tstanley,
Thank you for your feedback!  I have filed this as a syntax highlighting bug in our system.  The syntax highlighting feature should include this.
Warm Regards,
Daniel Dorroh
(3,723 Views)
I just encountered this bug with CVI 2017 version 17.0.0 (295)
I wonder if this bug is still present in later versions...
Very annoying bug!
(2,076 Views)
I just want to highlight that if you enable "Comment"  warning in the build options you will be notified in case a backslash exists in a c++-style comment line
(2,070 Views)
