LabWindows/CVI
Barchart with scattergraph
Hello, i have on my User Interface a scattergraph where i plot some points of some colorspaces.
I need in only one configuration an barchart like the following one to draw the rawdata of my sensor.
Is it possible to draw some bars with an scattergrap?
(3,271 Views)
Well, you could use the functions PlotY or PlotXY with the attribute VAL_VERTICAL_BAR, but this will give you identical colors; alternatively you could plot individual rectangles using PlotRectangle; Wolfgang
(3,269 Views)
Hi thanks for you fast answer, i´ve forgot to say that i want to do this in Visual Studio CLI / .net
And your examples are directly from Measurement Studio. Is there a possibility to do that?
(3,252 Views)
