LabWindows/CVI
Based on LabWindows/CVI using Modbus communication by means of RS-232
Hello !
Thank you for your help.
There may be my mistake. I will solve the problem as soon as possible.
Thank you  again for your support and help.
Best regards.
xiepei.
I wouldn't care success or failure,for I will only struggle ahead as long as I have been destined to the distance.
Message 11 of 26
(2,985 Views)
(Sorry for duplication of the message. I posted it as new message but I couold not remove the old one)
I am trying to use the Modbus Test CVI code from
Always there is a way! Try to find it.
Message 12 of 26
(2,758 Views)
(Answered here)
Message 13 of 26
(2,749 Views)
I am getting the CRC error whether its read or write and writes work sometines. Is there any way to solve it
Message 14 of 26
(2,499 Views)
Did you solve this issue?
Message 15 of 26
(2,507 Views)
did you solve the issue?
Message 16 of 26
(2,507 Views)
How you detect CRC errors?
Have you tried dumping messages and checking the CRC?
And have you tried checking the calculated CRC on write messsage?
Message 17 of 26
(2,498 Views)
Thanks for your reply. it was giving error 532, CRC error.
I figured it out.  It was something wrong with the slave unit I was working.
Message 18 of 26
(2,481 Views)
I am facing another issue. I am able to read from the device, but i cannot write anything to the device. It gives error 99. I/O operation timed out.
Is there any way to solve this.
I can write to my device when i use another modbus app which i got form internet.
Is there anything specific to the  Modbus testing program which i should take care of, when writing?
Message 19 of 26
(2,467 Views)
Which instruction is giving you this error? Can you post the relevant part of your code?
Since you say you can "read", this means you can write a query to the device and get a response from it, so you are already sending messages to your device without errors; given this, it seems possible that the problem is in how your write message is built and sent.
Message 20 of 26
(2,455 Views)
