LabWindows/CVI
Battery Status
I'm using the Windows SDK function GetSystemPowerStatus (LPSYSTEM_POWER_STATUS lpSystemPowerStatus) to obtain the status of a Laptop Battery.  On execution of this function I'm receiving a General Protection Fault, the reason for which, I'm not sure.
Can anyone help?
Thanks in advance.
(CVI 8.0.1, Windows XP SP2)
(4,303 Views)
Could you post a snippet of code showng the exact declaration and function call you are using?
JR
(4,294 Views)
JR,
Below is a snipet of the code used:
LPSYSTEM_POWER_STATUS lpSystemPowerStatus = 0;
    GetSystemPowerStatus (lpSystemPowerStatus);
James
(4,278 Views)
The function call is expecting a pointer, so the call should be:
    GetSystemPowerStatus (&lpSystemPowerStatus);
JR
(4,272 Views)
  you've just set a long pointer to a structure to zero, so the memory address being used is 0!!
Essentially you created a pointer and pointed it to nothing rather than to a defined memory space = GPF time!
Try this instead :
#include <cvirte.h>
#include <windows.h>
#include
<utility.h>
int main (int argc, char *argv[])
/* notes to show data layout of the system power status structure
 typedef struct _SYSTEM_POWER_STATUS {
  BYTE ACLineStatus;
  BYTE BatteryFlag;
  BYTE BatteryLifePercent;
  BYTE Reserved1;
  DWORD BatteryLifeTime;
  DWORD BatteryFullLifeTime;
 } SYSTEM_POWER_STATUS,  *LPSYSTEM_POWER_STATUS;
 SYSTEM_POWER_STATUS SystemPowerStatus;
  if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
    GetSystemPowerStatus (&SystemPowerStatus);
 return 0;
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(4,271 Views)
