LabWindows/CVI
Baud rate problems with bluetooth SPP and USB-dongle.
I'm receiving streaming data to Windows XP from a bluetooth module (WML-C46) with a serial port profile locked at 115200 baud. When using a RS232-BT dongle connected at COM1 it works fine. But if I try to use a USB-BT dongle or built in BT on a laptop the rate decreases to about 1/4 of before. Is there any flow control related limitations of SPPs via USB-BTs not present when using the serial port directly or what could be the reason? I'm using LabWindows/CVI 8.0.0 (273).
/Jimmie Hagblad, Sweden
Message Edited by jhagblad on 06-13-2007 08:17 AM
Message 1 of 1
(4,198 Views)
