LabWindows/CVI
Bazaar behaviour on break
Has anyone seen the CVI program loose it's place in a do while loop when the break->break program is selected?
Is this a bug?
Once the break program is executed while in the middle of a Do While loop and the resume is selected, the program resumes execution OUTSIDE the Do loop...
(3,045 Views)
Hello ASIC IIBU Tech,
Are you using "Break Execution Ctrl-F12" to break your program and then "Continue F5" to resume execution? If you are and you still think you are seeing an error, then you might contact us at http://www.ni.com/support or http://www.ni.com/ask. If you are pressing any of the toolbar buttons besides Go or using some other button to resume execution, CVI may be stepping out of your while loop at your command. The "LabWindows/CVI User Manual" explains the different buttons and their actions, please see Start >> Programs >> National Instruments >> Measurement Studio >> Online Help >> CVI Manuals or http://www.ni.com/manuals for further information.
Jeremiah Cox
(3,045 Views)
