LabWindows/CVI
Bessel functions for complex number
I need to calculate the Bessel functions of first kind for complex numbers.
I only found Bessel functions for real numbers it in the advanced analysis library.
Did I miss the Bessel evaluation for Complex numbers or is this function not available in the advanced analysis library.
I could neither find the Hankel functions.
Thank you
Bertrand
(3,678 Views)
Good afternoon,
You can't use Bessel VIs with a complex number (same for CVI) :
Message Edité par Nacer_M le 04-09-2008 09:59 AM
Nacer M. | Certified LabVIEW Architecte
(3,626 Views)
Is there any chance to get Bessel functions for negative and complex numbers (as available in Matlab) implemented in a future version of CVI?
Bertrand
(3,606 Views)
