LabWindows/CVI
Best/Smartest Communication between 2PC linked with LAN?
What for posibilties exist to make a connection between 2 PC.
1PC : CVI application
2PC : JAVA,C#,C++, Application
Should I use Data socket , or a tcp/ip protocoll, or ?
Thanks a lot !
(2,948 Views)
Hi david,
the easiest way would be to use the TCP/IP-protocol.
There are several examples available in CVI or on our Hompage.
Datasocket is probably no supported by JAVA,C++ or others.
A third possibility would be the usage of ActiveX-Components, but I think its more complicated than TCP/IP
regards
Peter Weber
NI Germany
(2,948 Views)
