LabWindows/CVI
Best method to gracefully terminate real time program.
I have a polling application running at 100 Hz.  When it receives various messages from a Windows application it starts performing some tasks.  I run it through LabWindows/CVI on a real-time target.  When I try to stop the program it crashes the PXI.  What is the best method to stop the program where the PXI will be in a state where I can restart the program through CVI?
This is how I'm currently trying to end it:
		while (!RTIsShuttingDown() && !flagRestart)
		   ProcessSystemEvents();
		   SleepUS (10000);
		setNextRunNumber();	// Save the current run number
		/* Thread cleanup code. */
		Done:
		DiscardAsyncTimer(-1);
		if (ai0TaskHandle) DAQmxClearTask(ai0TaskHandle);		// Stop DAQ AI thread
		if (ai1TaskHandle) DAQmxClearTask(ai1TaskHandle);		// Stop DAQ AI thread
		if (ai2TaskHandle) DAQmxClearTask(ai2TaskHandle);		// Stop DAQ AI thread
		if (threadPool)	CmtDiscardThreadPool (threadPool);	// CmtDiscardThreadPool waits for the thread function to exit.
		if (ThreadWriteDataToFile.tsqHandle) CmtDiscardTSQ (ThreadWriteDataToFile.tsqHandle);
		//if (DataFile) fclose(DataFile);					// when you want data add these lines back in!
		if (g_SessionRef) nxClear(g_SessionRef);				// Clear XNET session
		if (registered) UnregisterTCPServer (23);			// Stop TCP server thread
	    if (VaisalaTCPConnected) DisconnectFromTCPServer (VaisalaTCPConnectionHandle);
		if (ao0TaskHandle) DAQmxClearTask(ao0TaskHandle);		// Stop DAQ AO thread
		if (ao1TaskHandle) DAQmxClearTask(ao1TaskHandle);		// Stop DAQ AO thread
		if (ao2TaskHandle) DAQmxClearTask(ao2TaskHandle);		// Stop DAQ AO thread
		if (doTaskHandle)
			DAQDOChannels[0]->Value = 1;  					// RT shutting down so kill the engine
			for (int count = 1; count < numDOChannels; count++)
				DAQDOChannels[count]->Value = 0;			// Turn off all other digital channels
			DAQOutputDigital();
			DAQmxClearTask(doTaskHandle);					// Stop DAQ DO thread
		if (numTimers > 0)
			for (indexChannel = 0; indexChannel < numTimers; indexChannel++)
				Timer_Port_Close(indexChannel);
		FreeMemory();
		flagRestart = 0;
		flagStart = 1;
		if (RTIsShuttingDown() || flagClose)
			CloseCVIRTE ();
static int FreeMemory(void)
	int count = 0;
	while (DAQAIChannels[count] != NULL)
		free(DAQAIChannels[count]);
		DAQAIChannels[count++] = NULL;
	count = 0;
	while (DAQAOChannels[count] != NULL)
		free(DAQAOChannels[count]);
		DAQAOChannels[count++] = NULL;
	count = 0;
	while (DAQDOChannels[count] != NULL)
		free(DAQDOChannels[count]);
		DAQDOChannels[count++] = NULL;
	count = 0;
	while(CLControls[count]  != NULL)
		free(CLControls[count]);
		CLControls[count++] = NULL;
	count = 0;
	while (Safeties[count] != NULL)
		free(Safeties[count]);
		Safeties[count++] = NULL;
	count = 0;
	numModes = 0;
	while (Mode[count] != NULL)
		free(Mode[count]);
		Mode[count++] = NULL;
		free(DAQDevices);
		free(aiRawData);
		free(aiTask0RawData);
		free(aiTask1RawData);
		free(aiTask2RawData);
	numaiTask0Channels = 0;
	numaiTask1Channels = 0;
	numaiTask2Channels = 0;
	return 1;
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(1,010 Views)
I figured it out.  I thought CloseCVIRTE(); would close it, but it didn't.  I needed to get out of the infinite while loop and call return;
Here is a short snippet as a starting point for a polling application.  There may be better ways, and if so, I welcome the feedback.
I pulled this out of my program so it may or may not run, but it should be close.
#define Hz_LOOP_RATE 100
static short		flagClose = 0;   // allows you to bounce out of primary while loop to end program
static short 		flagClosed = 0;  // confirmation that program can end
static short 		flagRestart = 0; // flushes memory and restarts from the beginning
static short		loopCounter = 0; // counts from 0 to 99 inside of the 100 Hz loop
void CVIFUNC_C RTmain (void)
   if (InitCVIRTE (0, 0, 0) == 0)
      return;    /* out of memory */
   while (1 && !flagClosed)
      // Start a 100 Hz timer  Hz_LOOP_RATE = 100
      NewAsyncTimer (1.0 / Hz_LOOP_RATE, -1, 1, MainLoop, 0);
      while (!RTIsShuttingDown() && !flagRestart && !flagClose)
         SleepUS (10000);
         CloseCVIRTE ();
         flagClosed = 1;
   return;
int CVICALLBACK MainLoop (int reserved, int timerId, int event, void *callbackData, int eventData1, int eventData2)
   if (event == EVENT_TIMER_TICK)
      _100HzCode();
      if (loopCounter % 10 == 0)	// 10 Hz functions
         _10HzCode();
      if (loopCounter % 50 == 0)	// 2 Hz functions
         _2HzCode();
      if (loopCounter == 0)		// 1 Hz functions
         _1HzCode();
      loopCounter++;
   return 0;
(979 Views)
