LabWindows/CVI
Blue screen Measurement & automation explorer
Hello everyone,
I've just installed the measurement and automation explorer (version 4.7.0f4) to run a second software: power measurement device, on a new Toshiba laptop, it has Windows 7, but sometimes a blue screen appears when I'm acquiring data. I've been told it might be a problem with software incompatibility. I am going to buy a new laptop just for this purpose, what characteristics must it have so I no longer see this blue screen?
Message 1 of 8
(4,005 Views)
I never had problems like yours with MAX with very different machines, even quite old and with limited resources, so I'm not able even to think of a specific technical data to look at while selecting a PC.
Is there a reason for you to install that specific version of MAX, which is not the more recent one? Could you try to download and install the last one?
Message 2 of 8
(3,996 Views)
Kareng, can I ask where you found the version 4.7.0f4 driver?  I am needing it to do some testing and haven't been able to find it.
Message 3 of 8
(3,702 Views)
Hi Kareng;
You can find the general requirements to work with MAX and LabVIEW
Requirements for LabVIEW Development Systems and Modules
http://www.ni.com/labview/requirements/esa/
Usually Dells computer (from my personal experience) work really well with NI software, just make sure you have a supported OS (win 7, Win 8.1) and not the home version.
The LV version you should install (no matter if using 32 or 64 bits) should be LabVIVEW 32 bits, just because it supports more modules.
Also; the amount of RAM memory allocated for LV is usually limited to 2 G in 32 bit and 4 G in 64 bit systems
How Much Memory can LabVIEW 32-bit or 64-bit Use?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAEOSA4&l=en-US
Hope this info helps
Greetings
Message 4 of 8
(3,688 Views)
@aconnors27
Kareng has not updated this discussion any more from the first post in april 2013; even more, he/she hasn't posted any more in the forums: you're not likely to get any response from him/her!
Is there a particular reason for you to look for a so old version of MAX?
@MarisolM
We all know the NI is "the LabVIEW company" Smiley Wink but there is no evidence that the user is using LabVIEW since he's posting in the LabWindows/CVI board! Smiley Surprised Smiley Wink
Do the informations you reported apply to CVI as vell as LV or there are similar documents specifically focused on CVI? If so I'd be interested to take a look at them: can you post the links?
Message 5 of 8
(3,665 Views)
Roberto;
The requirements for CVI are quite simmilar to the ones from LabVIEW, varying only in disk space requiremments.
You can check them out in the readme file of your CVI versión, you can find the one for CVI 2013 Sp1 here
Have a good day!
Message 6 of 8
(3,656 Views)
@RobertoBozzolo
Thanks for the reply.  We need the old version because our test fixtures are controlled and we can't upgrade from the approved version without major testing and validation.  Any ideas?  Should I email NI directly?  Thanks!
Message 7 of 8
(3,650 Views)
Your version of MAX is hardly relevant. It is the driver (i.e. DAQmx) that you would need. You should really know what version of the different drivers your software was validated with.
Message 8 of 8
(3,642 Views)
