LabWindows/CVI
Borland C++ 4.52 and LabWindows/cvi
I am using Borland C++ 4.52 compile to compile a sample code of LabWindows/CVI 5.5 (i.e. sample 5.5). It was compiled and liked, and a exe file was created. However, when I run the excutable file, nothing happend. the code started, then stoped, no any error or message. Could you let me know why?
(3,159 Views)
Not sure why it does it, but this may help...
What I suspect is happening is that the CVI RTE is not being loaded and your exe is returning at that point. Thats all I can think of at the moment.
You do have the CVI RTE installed on the machine you are compiling the Borland code haven't you ?
Actually, the above is not going to be much help if you don't have the CVI RTE installed, since the OS should have moaned when you started the EXE that a library required by your example could not be found.
Are you able to single step the code from within Borland ? Does it get into the main ?
Hope this helps
Chris
(3,159 Views)
The CVI Runtime engine must be loaded. To do this you need to include
the following function call at the beginning of your program:
InitCVIRTE (hInstance, 0, 0)
(3,159 Views)
