LabWindows/CVI
Breakpoints and Non-Fatal Errors crash Win2000
I am using a PXI 6071E Multi-function daq card connected to a PXI 1000B chasis. The PXI chasis is connected to my computer through a MXI-3 8330. Connected to the PXI 6071E is a SH1006868 cable that slpits and goes to two 68 pin connectors that I have attached to two TBX-68 interface blocks. I wrote a simple program using LabWindows where I generate a random voltage from 0v to 5v and send it to the analog out then I read it back in on the analog inputs. It works fine but if I get a non-fatal error or if I set a breakpoint and then try to stop execution, the next screen I see is blue and the computer restarts. This is not specific to any one program. I have duplicated the same fault by running some of the sample prog
rams that come with Measurement Studio.
(2,894 Views)
I looked through the CVI code on this, and do not see any issues in your code. Anywhere that you put a breakpoint, and then stop execution, you get a "blue screen" death? I'm not aware of anything that would cause this, but I am going to drop this to the DAQ supporters and see if they could add anything.
(2,894 Views)
DanielMcchane wrote in message news:<50650000000500000024700000-1017707437000@exchange.ni.com>...
I am experiencing this problem too!
Have the "DAQ Supporters" had anything to add?
(2,894 Views)
