LabWindows/CVI
Bring to front objects in .uir
I have a good one:
Overlapping objects in .uir file, is it possible to control which one is over the other ?  I want to use pictures as background and button/control over the background.  Sometime the background is hiding the button and sometime the button is over the picture as I want.. but how to control this ??
Any help would be very appreciated,
(3,825 Views)
The Arrange>>Control ZPlane Order menu contains a number of commands that allow you to control the relative order (front to back) of the controls on your panel.
Hope this helps.
Mert A.
(3,818 Views)
Hi.
In the UIR editor, you can control the "z-plane" order of controls through the Arrange menu item (see attached image).
Colin.
Note: I am using CVI v7.1.1; your menu choices may be slightly different.
(3,816 Views)
