LabWindows/CVI
Buffered Digital Output on NI9401
Hello All,
I have a cDAQ system with different modules inside and  I used the system in the past without problem.
Now I'm having a new need: produce 8 different pulse train using the 8 lines of the module NI9401.
I succeed doing that, if I use single Write commands divided by Delay() function. Of course this is not the optimal solution.
I've tried using the buffered output but, for sure, I have not understood the mechanism.
Here attached the code I'm using for the preliminar test.
In the first image I get the error of slot position (I was currently using the system with NI9401 in slot 5).
In the second image I move the module to slot 3 and I get another error.
Is there anybody who can help me?
Sergio
(2,967 Views)
Hi Laser,
It looks like a correlated Digital I/O to me.
You should check these two documents
NI-DAQmx: Correlated Digital I/O with NI CompactDAQ and LabVIEW
http://zone.ni.com/devzone/cda/epd/p/id/5256
Can I Use Different Sample Clocks for Correlated DI and DO?
http://digital.ni.com/public.nsf/allkb/79608CDF0C0D28AA862573400042D4F8?OpenDocument
Basically the 9401 isn't able to create a clock on it's own. You have to generate this clock "externally" I mean with another module.
You can chose either an analog input/output module and use the analog timebase (ai/sampleclock) to drive the digital I/O operation or use a digital module in slot 5 or 6 and use the counter to produce the clock needed (ctr0/internaloutput).
Hope this helps
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(2,946 Views)
