LabWindows/CVI
Bug: CompareStrings() in UTF-8
I found a bug inside CVI2020. If I use the formatio.h function CompareStrings() inside a UTF-8 project two unequal strings recognised as equal.
Use the example "listbox" (look inside description of CompareStrings)
Change row 79 to this:
if (CompareStrings (label, 0, removeitem, 0, 0) == 0)          0 = Specify 0 or select No in the function panel to match characters on a case-insensitive basis.
Add these new items with name:
test
test123
Then remove test123. program remove only test123
Switch project to UTF-8 and repeat the example:
program remove test and test123
If I change the parameter from 0 back to 1 (case-sensitive), then the function works.
Message 1 of 1
(455 Views)
