LabWindows/CVI
Bug in assignment statment
[1] I can't find the version of C you're using. ANSI 1989, Addendum 1994/1996, ANSI 1999?
[2] The following statements show an error. I believe the error is bogus.
# define max(a, b) ((a) < (b))? (b): (a)
# define min(a, b) ((a) < (b))? (a): (b)
enum { PSAMaxLine          = 160                      // Maximum characters in a line
     , PSAMaxIndent        =  28                      // Maximum nesting levels
     , PSAIndentInc        =   2                      // Columns to indent at each level
typedef struct Thread { int    Indent;
                        char   Chr;
                        char * Prefix[PSAMaxIndent+1];
                      } Thread;
                     // Indent  Chr            PSAPrefix
Thread  TArray[1] = { { 0,      '|', "\0 | | | | | | | | | | | | |" } }; // TArray
int           PSADebugFlag =   1;                     // Global Debug (0/OFF 1/ON)
void PSAEnter(char * Name, char * Data){              // Output Procedure Enter line
  TArray[0].Prefix[max(0, min(TArray[0].Indent, PSAMaxIndent))] = TArray[0].Chr;
}; // PSAEnter
error: Operands of = have illegal types 'pointer to char' and 'char'.
The expression on both sides of the '=' sign are 'chars'
The following expression has worked.
char * Prefix =
"\0 | | | | | | | | | | | | |";
Prefix[max(0, min(Indent, PSAMaxIndent))] = '|';
[3] 'inline int max(a, b) { return ((a) < (b))? (b): (a); }'
    is valid ANSI 1999 C but invalid NI C.
[4] [2] and [3] have been compiled as correct on ANSI 1999 compliant C compilers.
art
(3,192 Views)
I'd have to agree with CVI's ANSI89 compiler: on the left of the assignment statement in error you have selected the .Prefix structure component - you have defined this as an array of character pointers, so de-referencing it once will give you a character pointer, not a character. Perhaps a typo has crept in, somewhere?
JR
(3,170 Views)
