LabWindows/CVI
Bug on changing panel attributes within LabWindow/CVI 7.0
I upgraded from LabWindows/CVI 5.5.1 to 7.0 and accunter some problems with LW/CVI 7.0 when I want to change some panel attributes on my .uir file, as Enabling/Disabling "Scale Contents On Resize", those changes are not taken into account. It is really a problem!
(What is also noticed is that the "Other Attributes"-Button and the related "Ok"-Button have to pressed two times before reacting).
Thank you in advance for the issues you can give me to fix this problem with LW/CVI 7.0
(3,089 Views)
Could you attach a sample here? I would like to see if the same problem is happening on my machine.
Bilal Durrani
NI
Bilal Durrani
NI
(3,089 Views)
Curiously, it only happened yesterday (first day I was using the new LabWindows version on my machine) and I could also reproduce it each time on new panels for the project. But today, all seems to work normally again (also does the strange double clicks).
I think it had something to do with the transition from LabWindows 5.5.1 to 7.0. It was maybe because the project was not saved in 7.0 at this moment.
Thanks for your support.
Rachel
(3,089 Views)
