LabWindows/CVI
Build a dll under CVI without cvirt(e)
we have developed a dll under cvi 7.0. Now, as i understand we need to also distribute the cvi runtime dll. Is there a way to create a dll without needing the runtime dll neccessary?
What functions may not be use then?
David
(3,381 Views)
No, any DLL developed in CVI will depend on the one of CVI's runtimes, just as all Visual C++ DLLs would depend on the VC++ runtime. We do give you two options:
1) The full CVI RTE (supporting all CVI functions and libraries)
2) Instrument Driver Only support (supports a small subset of CVI functions and libraries, this mode is designed for instrument driver developers that want to distribute a very small runtime).
Consult the help under the DLL Target Settings for more information.
Best Regards,
Chris Matthews
(3,381 Views)
