LabWindows/CVI
Build.exe ActiveX Example...Selecting Active Project
On my last project we used the Build.Exe program in a batch file to build all the static libraries for the software (in the correct order) and then the main executable.
I wanted to do something similar for my new project, but some of their CVI project files contain multiple project entries.  To do it manually I would open the PRJ file and right click on each one to make it active then build it.
What I want to do is modify BUILD.EXE so I can create a batch file as follows:
build "d:\Projects\MyProject.prj" -ActiveProject "MyFirstProject" -useExisting -log "MyProject_MyFirstProject_build_log.txt"
build "d:\Projects\MyProject.prj" -ActiveProject "MySecondProject" -useExisting -log "MyProject_MySecondProject_build_log.txt"
I do not know what CVI function to call though, or even if this is possible?
Thanks.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(4,433 Views)
You mean, like "compile Project.prj" ?
You can make a cygwin bash script to extract the prj files from the cws file
for instance an execute compile on them.:
grep "Project 00.*\.prj" *.cws | sed -e "s/.* \"/\"/" | xargs -l compile
or something similar.
Guillaume Dargaud
http://www.gdargaud.net/
(4,418 Views)
I am using CVI 8.0.0.  That project does not exist on my installation.  So cannot check...
Problem is I do not have Grep on my Windows XP PC.  As it is a work PC I am not allowed to install it.
Christopher Povey
(4,409 Views)
Hi Christopher,
Thank you for contacting National Instruments. I have been doing some investigation into this problem and I have a couple of suggestions.
I am currently using CVI 8.5. but I think the operation should be very similar. Can you verify that you can see an Exe file called "Compile.exe" in the root directory of your CVI installation. You should be able to use this to compile your projects. You could then copy all of the commands that you are using into a text editor to create a Batch file which will compile everything at once.
I've attached the syntax of this command. I will also be installing CVI 8.0.0 to try and emulate your setup.
C:\Program Files\National Instruments\CVI85>compile
Library 'Traditional NI-DAQ Library' not loaded.
Library 'NI-IMAQ I/O' not loaded.
LabWindows/CVI Command Line Compiler
Command line arguments are:
     <filename>
     -debug
     -rebuild
     -log LOGFILE
     -logappend LOGFILE
     -fileVersion w,x,y,z
     -productVersion w,x,y,z
     -fileVersionString FILEVERSIONTEXT
     -productVersionString PRODUCTVERSIONTEXT
     -DDEFINE
Please let me know how you get on.
Many thanks,
Andrew McLennan
(4,322 Views)
I do have compile.exe in my CVI directory.  When I get five minutes I'll have a play with it.
Thanks.
Christopher Povey
(4,315 Views)
