LabWindows/CVI
Building ActiveX Servers in LabWindows (using CVI Tools) & reuse LabVIEW code already develop when building the server
I want to build an ActiveX server using LabWindows tools : ActiceX server wizard ; but i want to implement (incorporate) VI,llb library, GOOP Object already develop in LabVIEW.
What in the best method (& the easier way) to incorpore LabVIEW Code : Transform my VI's (GOOP Object) into DLL and then call them in the ActiveX Source file ?
I have read in the Application Note 192 (Building ActiveX Server in LabWindows/CVI) page 4 ("Server Settings Panel") that we can Import Function Tree (.fp File) to create Object in the server. Exist there a way of creating a file .fp file from LabVIEW VI (llb)?
If someone has got an example, it will be great ; so i
can base me on the example to develop mine.
Thank you very much
Derek
(3,197 Views)
Hello Derek
Currently there is no automated way to generate fp files from VIs or LLBs. Your best bet is to use application builder to create a dll from your VI's and then call the functions from CVI that way.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,195 Views)
