LabWindows/CVI
Building a distribution stops in middle of process
Building a distribution for one of my project works fine on one computer but on another computer it stops at the following step.
I have to kill the application to get out of this situation.
What could be the reason for this behaviour ?
I'm using CVI 2019.
(1,632 Views)
Not really enough info provided to solve the problem but possible suggestions would be:
  • Missing Instrument Driver Packages on second system
  • Different paths to required components on second system
  • Insufficient memory or RAM on second system
Greg B
(1,594 Views)
 think I've had the problem when I copied the entire build directory. Try to delete the distribution and re-create it (under a new name). In most cases it's quick to do.
(1,583 Views)
