LabWindows/CVI
Button problem in tabPanel
hallo,
I have a little Problem with a button in a tabPanel.
I have uploaded the cut down version of my program.
What I would like to have:
click on the button in the tabPanel >> text output in the string window
Who can halp me?
What's wrong in my program?
Message 1 of 10
(4,663 Views)
Please attach your source code if you want anyone to find a problem.
Attach *.prj, *.uir, *.c, *.h. For a typical project, you don't need to post any other files.
Do not attach *.exe, *.cdb, *.nidobj, or *.niobj. These files just inflate the size of your post and are easily rebuilt if you post the source files.
Message 2 of 10
(4,646 Views)
ok, here is only the *.prj, *.cws
I could start it with only this two files.
I think thats all you need. I hope!
Message Edited by Greber on 04-18-2005 07:52 AM
Message 3 of 10
(4,647 Views)
Sorry, we need the source files I listed in my first post.
Based on the contents of your .prj file, it looks like you need to post the following files (and no others).
versuch.prj
versuch.uir
versuch.c
versuch.h
Message 4 of 10
(4,638 Views)
ok in this *.zip is the *.prj, *.c, *.h and *.uir
Message 5 of 10
(4,637 Views)
Trying to open this one I get the error message: "Cannot open file: it does not appear to be a valid archive."
Message 6 of 10
(4,628 Views)
Me too.... "it is not a valid archive", please, re-post a valid one, so that we can examinate it!
Bye!
Message 7 of 10
(4,620 Views)
Hallo again,
so I wrote this little program again and will now post it.
It contains:
output.c output.h output.cws output.prj output.uir
Thanks for your patience.
Florian
Message 8 of 10
(4,603 Views)
Hi Florian,
your problem is related to the Tab panel's principle: the tabbed panels are child panels of the panel onto which are located, and they have different handles, so you cannot acces control on the main panel with the handle of the tabbed one.
In your SICKNESS_FUNC callback modify the code as follows:
GetPanelAttribute (panel, ATTR_PANEL_PARENT, &parentPanel);
SetCtrlVal(parentPanel, PANEL_STRING, "HALLO");
In case you need to heavily access controls on different panels inside your program, you could consider storing their handles into global variables to access them more easily.
Roberto
Message 9 of 10
(4,591 Views)
thank you so much!
it works. thx
Florian
Message 10 of 10
(4,582 Views)
