LabWindows/CVI
C++ classes
I'm using CVI 8.0.  From what I see the compiler is still a 'c' only compiler. Is this true.
I'd like to introduce some class (C++) functionality.  Is the only way to do this, through an external compiler????
MikeF
(4,511 Views)
This is true.  It is still compliant only with ANSI C.
The C++ additions are not compatible.
(4,490 Views)
Darn double print. (and it seems you can't delete a post....)
Message Edited by scomack on 03-02-2007 07:25 AM
(4,490 Views)
Hi MikeF,
There are also a couple other options for using C++ and CVI. See the following links for more information.
Is LabWindows/CVI a Compiler and What C Functions Can LabWindows/CVI Use?
Does LabWindows/CVI Support C++?
Integrating LabWindows/CVI with Microsoft Visual C++
Test Engineer - CTA
(4,476 Views)
Howdy Mikefr00,
If you have some C++ code that you would like called from LabWindows/CVI, one option could be to create a DLL out of the C++ code and then call it from C.  Check out
Using Dynamic Link Libraries with LabWindows/CVI tutorial.
Also, if your curoius about the CVI compiler, read the LabWindows/CVI Compiler KnowledgeBase.
Additionally, when mixing C and C++, I like to refer the How to mix C and C++ website. Its actually got some good information in it.
Hope this helps!
Best Regards,
Jonathan N.
(4,473 Views)
Thanks for all of your replys!!!
Mikefr00
(4,454 Views)
