LabWindows/CVI
C99 aggregate type non-constant initializers
So if CVI supports C99 non-constant initializers for an aggregate type like a struct, how come I can't do this in CVI 2010:
int intfunc (void);
typedef struct _myStruct {
  int value;
} myStruct;
myStruct  foo  = {intfunc()};
function call is a postfix expression and C99 says you can initialize an aggregate type with an expression.
(4,286 Views)
C99 only allows this for local definitions within a function, not for global declarations (c99 chapter 6.7.8 paragraph 4).
(4,277 Views)
Thanks - yes, I was trying this as a top level variable.  C99 restricts to block scope for variable arrays too so shouldn't be surprised I guess.  Designers didn't want to require elaboration at runtime of top level stuff.
(4,263 Views)
