LabWindows/CVI
CAN Frame to Channel Conversion Library
Is it possible to use this DLL with CVI? If so, is there any example code or a user document?
Cheers,
John
John C
(4,019 Views)
Hi JGC
Unfortunately this Library is only meant to be used from LV and LVRT, an equivalent Library does not exist in CVI.
With that said, you may be able to dig into the LabVIEW VI's of the Frame Channel Conversion Library and pull the function prototypes from the Call Library Function Node on the block diagram of each one. With this information, you could call the functions from the dll (usually located here: C:\Program Files\National Instruments\NI-CAN\CAN Frame Channel Conversion Library 1.0.2\Drivers) from within C.
Kind Regards
Chris
Chris | Applications Engineer NIUK
(3,999 Views)
Hi Chris,
Thanks for the reply.
Digging into the VI's assumes I have LV which I don't, so that solution won't work for me.
It is possible to use the NI-CAN channel functions such as nctGetProperty() to parse the channel information and then use that data with the NI-CAN frame functions to do somethig similar to the library. Since I don't need all of the capability in the library it shouldn't be too time consuming.
John C
(3,994 Views)
Accepted by topic author JGC
No, that's not going to work, but I've just discovered the virtual channels 256 & 257Smiley Happy
John C
(3,985 Views)
