LabWindows/CVI
CANopen transmission using Labwindows CVI
I am trying to implement a transmission via CANopen bus. I am programming on Labwindows CVI and I would like to know if it is possible to implement this transmission (SDO and PDO) with the Ni-CAN function library. Every source code exemple are welcome.
(4,092 Views)
It definitely is possible. NI-CAN provides access to the raw CAN communication through its frame API. Writing a CANopen communication layer on top of that is certainly possible although not a trivial exercise.
Unfortunately I have no examples I could show you for this.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,047 Views)
