LabWindows/CVI
CNVNewVariable() argument is invalid
Just such a syntax : "CNVNewVariable("\\\\localhost\\cnvtest.exe", "mycnv");" it always report error. which argument is wrong?
David
(3,892 Views)
By the way, may I need open the TCP port 59110 before using the network variable?
(3,891 Views)
The wrong parameter is possibly the network variable path, which is not the name of the executable but the one you have created either programmatically with CNVNewProcess or in the iteractive application.
(3,888 Views)
Hi Roberto,
I use the following code:
char process[] = "mymcnvtest";
int main ()
    char path[256];
    CNVNewProcess(process);
    CNVStartProcess (process);
    strcpy(path, "\\\\192.168.0.62\\");
    strcat(path, process);
    CNVNewVariable(path, "mycnv");
    CNVDeleteProcess (process);
the CNVNewVariable() still report the argument is invalid error.
(3,876 Views)
The first argument to CNVNewProcess is a machine relative path - meaning, you do not specify the machine's name or IP address but rather, <process>\<folder>\<sub-folder>\<sub-sub-folder>\<etc>.
So, in your example, the call would be:
    CNVNewVariable(process, "mycnv");
(3,860 Views)
Now it is working. Thanks Mohan.
(3,854 Views)
