LabWindows/CVI
[CVI 2009] Unexpected trailing tokens on directive line ignored.
Hello
We use CVI 2009 and we have this warning :
Test.prj(Debug) - main.c - 1 warning
 1, 1   Warning: Unexpected trailing tokens on directive line ignored
The first line of the main is just a comment.
Have you ever seen this? Do  you have any idea to wich line is ignored?
Regards
Etienne RABY
Message 1 of 17
(5,376 Views)
The fact that a line is a comment does not stop the compiler/preprocessor inspecting and acting on it. (As here, for example.)
Post the line and we might be able to help a bit more.
JR
Message 2 of 17
(5,362 Views)
The first line of the main...
Information about soft
I don't understand...
Message 3 of 17
(5,359 Views)
Did you create the file within CVI or import it from an external editor? (Thinking of CR/LF compatibility here)
JR
Message 4 of 17
(5,346 Views)
Thx for your answer.
I have check with notepad++ : the main is ANSi coded and the end line are CR/LF (I have tried to compile with just CR and just LF : same warning.)
Juste the first character of the first line is highlighted...
Message 5 of 17
(5,324 Views)
If it's a small project can you post it here?
Nacer M. | Certified LabVIEW Architecte
Message 6 of 17
(5,319 Views)
Currently, I don't have rights for this... And it's not realy a small project 🙂
Just an idea : if a field of the target setting is not correctly written, can we see this warning? Or maybe a bad line in the .prj?
If I have time, I'll try to create a new project with the same code...
Message 7 of 17
(5,316 Views)
Hello
I have more information about this and the problem is probably not with the code:
Compile Warning
Preprocessor line contains harmless trailing tokens that the compiler ignored.
Message 8 of 17
(5,312 Views)
So can you go to Option>>Preprocess Source File in order to see if there is no problem.
Message 9 of 17
(5,311 Views)
It's a good idea.
I'have tried to look, but the file contain 74000 lines...
Message 10 of 17
(5,295 Views)
