LabWindows/CVI
CVI 2010 SP1 Graph Control Resizing Following Panel Resizing Bug
Steps to duplicate:
- In a running application, compress a panel containing a graph control with a top x-axis down to some very small size.
- Re-expand the panel.
Observed behavior:
- Graph control is drawn abnormally large (larger than panel size; abnormally large fonts).
- This is only seen with graphs with top X axes.
(2,991 Views)
Hello -
I'm not able to reproduce what you're seeing.  Could you please post a small example project that reproduces what you're describing?
Thanks -
NickB
(2,987 Views)
