LabWindows/CVI
[CVI 2013] How can I get a folder size ?
How can I get a folder size to display on CVI ?  (This folder contain many sub-folder and many files).
In my application, The user select a folder, then he should see the size of the selected folder in the interface.
Thanks in advance,
Houssam
(4,232 Views)
Unorthodox, dirty and nasty answer: let the system do the work for you!
Launch a "dir . /s >> dir.txt" command, open the output file dir.txt and in the last-but-one line you'll find the figure you want!
On my system the command took <2sec to create a 67500+ lines file on a heavily nested subtree, with this output:
 Il volume nell'unit… C è Acer
 Numero di serie del volume: ******
 Directory di c:\Temp
23/06/2016  16:46    <DIR>          .
23/06/2016  16:46    <DIR>          ..
03/10/2014  12:16            25,614 20141003 stato MAX.nce
24/03/2016  14:44             1,383 20160324 Errore Norton.txt
25/03/2015  10:39             5,871 Verifica stampe - 256.pdf
03/02/2015  10:32             5,870 Verifica stampe.pdf
               5 File         28,227 byte
     Totale file elencati:
           43832 File 12,132,582,012 byte     << ==== Total subtree size
           10058 Directory  107,969,974,272 byte disponibili
I'm not aware of a single function that does what you want and if I'm to loose my time on a recursive function that scans the path an sums up files and.... I go the nasty way! Smiley Wink
(4,226 Views)
Yes I undrestund, thank you.
Bu how to execute the Cmd instruction, and how can I copy the result to my CVI code ? Do you have an example please ?
Thanks in advance,
(4,222 Views)
You can issue the command using LaunchExecutable () or System () , then parse the output file with File I/O functions.
(4,219 Views)
A little correction: I suggest to use the command "dir . /s > dir.txt" that regenerates the output file each time, while ">>" command appends data to existing content if the file already exists.
(4,204 Views)
thanks a lot!~
(2,459 Views)
