LabWindows/CVI
CVI 2013 executable does not exist?
Ocassionally, I get teh following error on some (not all) of my CVI 2013 projects:
"the specified executable does not exist"  See the attachment.  If I simply make the project again (or again), the error eventually resolves itself.  Any ideas?
Message 1 of 22
(7,530 Views)
Greetings.
When you say that you make the project again, are you talking about recompiling/rebuilding?
Brandon V.
Message 2 of 22
(7,486 Views)
Sorry, yes that's what I meant.  I simply CTRL+M or enter Debug repeatedly and the problem goes away.
Message 3 of 22
(7,471 Views)
When does the error get thrown? Also, is your data being stored locally or on some sort of network location?
Message 4 of 22
(7,451 Views)
Hi ElectroLund,
Are your project files on a network location? If you get this error in the future, can you check whether a built executable exists in project folder?
Daniel
Daniel Dorroh
Message 5 of 22
(7,450 Views)
Thanks guys,
So I am working locally.  I check out my project to a local folder from our SVN.
The error first is thrown when I click the Debug green icon.  I simply click it again and usually by the second time it builds correctly.
For what it's worth, I don't believe I ever saw this in CVI 2012.  I'm only now seeing it with 2013.
Message 6 of 22
(7,446 Views)
Does this only happen right after you check out your project?
Daniel
Daniel Dorroh
Message 7 of 22
(7,442 Views)
Hmm, that's an interesting thought.  I'll pay closer attention, but I don't believe it's that predictable.  It seems to be relatively random.
Message 8 of 22
(7,439 Views)
Ok, after working a few hours on a checked-out project, I can confirm that in about 2 dozen build/debug cycles in a 2 hour period, I had this error one time out of the blue.  It wasn't on a fresh checkout, just right in the middle of my developing.
Message 9 of 22
(7,433 Views)
Hi, all,
I'm facing this same problem (but very rarely) - and I suppose this is and I suspect that it is associated to multicore processor configuration of local machine.
Changing from dual-core (HP 8530p) to new DELL Vostro 3560, i7-3612QM @ 2,1 GHz I encounter this and also another weird behaviour (e.g.).
Have no idea to overcome this.
George
Message 10 of 22
(7,418 Views)
