LabWindows/CVI
CVI 2015 - SSP ?
Hello all,
I see CVI 2015 in the list of service pack updates, but it comes with a lock that says I don't have a contract with the Standard Service Program. I normally have a full site license, so is that something extra, something new, or is it due to the fact I'm still on WinXP ?
Thanks.
(5,385 Views)
This is the standard Update Service behavior for SSP updates such as service packs and new release updates. SSP is tied to the serial number activated on your computer. How do you normally license LabWindows/CVI on your computer?
Daniel Dorroh
(5,367 Views)
We have a licence server for all NI products for the entire lab (yeah, we are good customers...). Is it the licence server that may not up to date (I can ask them) ? Or my PC not doing things right with the licence server ?
(5,348 Views)
Since you are on a VLA, your software activation is not going to be tied to a serial number, which is used to check whether you have SSP. The recommended approach here is to disable SSP checking through NI Update Service. You can do so by enabling File»Preferences»Unlock updates for which service is expired.
Daniel Dorroh
(5,320 Views)
Thanks for the tip, I'd never noticed that option before. But it says that CVI2015 requires .NET 4.5, which I downloaded and which refused to install: WinXP not supported. So I guess that's it, I'll have to bite the bullet and ditch XP at some point.
(5,298 Views)
I apologize for not addressing the comment about XP earlier. The supported operating systems for LabWindows/CVI 2015 are as follows:
  • Windows 8.1 (32-bit and 64-bit)
  • Windows 8.0 (32-bit and 64-bit)
  • Windows 7 (32-bit and 64-bit), including Starter Edition
  • Windows Server 2012 R2 (64-bit)
  • Windows Server 2008 R2 Service Pack 2 (64-bit)
Also, to be specific, LabWindows/CVI 2015 requires the .NET Framework 4.5.2. I hope that information helps.
Warm regards,
Daniel Dorroh
(5,282 Views)
