LabWindows/CVI
CVI 2019 Debug 64 bit error "_ExtractParamInfo" could not be found
Just migrated code from my development computer (CVI 2017 W10) to my laptop (CVI 2109 W7 SP2).
I should mention that this a new install on CVI2019 from the beta.
Release64 compiles, launches, and runs fine.
Debug64 compiles, fails on launch with the following error "The procedure entry point _ExtractParamInfo could not be located in the dynamic link library cvirte.dll."
Pic of error and NIMAX report attached.
Looking for help. Thanks in advance.
Greg
(3,478 Views)
Your image shows some licensing wizard errors and your email address - not the _ExtractParamInfo error you describe.
(3,422 Views)
Apologies. This should be the appropriate file.
(3,418 Views)
Are you deploying the Application into your new computer with LabWindows CVI 2019? Is the error appearing when you run the application?
The Run Time Engine of LabWindows CVI 2019 should be able to run applications developed in previous versions of LabWindows/CVI.
(3,396 Views)
In each case, I am running from the code base with a few dlls linked in.
The program has been successfully compiled and run in the following IDE environments on two separate computers
CVI 2017 Release64 Dev Comp W10
CVI 2017 Debug 64 Dev Comp
CVI 2017 Release64 Laptop W7 SP2
CVI 2017 Debug64 Laptop
CVI 2019 Release64 Laptop
The same code compiles without incident but fails to fully launch with the supplied error in the following case
CVI 2019 Debug64 Laptop
I am trying to evaluate the the impact that upgrading might have on various projects on the dev computer. Currently those plans are obviously on hold.
Greg
(3,387 Views)
Hi Greg,
Could you share a screenshot of the error you get when you compile / run the executable when using Debug64 with CVI 2019?
(3,357 Views)
Here are the screen shots. The program compiles successfully. The first error popups right as the program attempts to run and before the GUI pops up. Second error happens after the first error is dismissed and CVI grinds for about 30 to attempt to "recover".
Greg
(3,352 Views)
