LabWindows/CVI
CVI 5.5.1 Compiler Error?
Can anyone tell me why the following code compiles correctly under CVI 5.5 but does NOT compile under CVI 5.5.1?
unsigned char test1 = (signed char)5.0;
unsigned char test2 = (unsigned char)5.0; /* Compile errors: why? */
signed char test3 = (signed char)5.0;
signed char test4 = (unsigned char)5.0; /* Compile errors: why? */
This is a new version of the same question I posted a few hours ago.
Urgent need for help thank you!"
(3,243 Views)
Giovanni...
I tried on it on my CVI 5.5p1 and it compiled fine.
What are the errors that you got back?
I have my compiler set to MSVC, what is yours?
I also had all warnings set in the compile options.
It even ran and worked as expected.
Let us know the errors you were getting and maybe I can tell you more,
Sorry,
Chris
(3,243 Views)
I too was able to compile correctly, I am not sure as to why you are getting this error. Please report back exactly what you are seeing. Thanks.
(3,243 Views)
