LabWindows/CVI
CVI 5.5 very slow
I use cvi 5.5! When i want to compile my project
it takes a very long time(up to 2 minutes)! I use a AMD K6 450MHz 128 MB
RAM
so I think the PC is not the Problem!
Does anyone know some settings to increase Compile-Time!
Or is it a generally Problem!
Thanks for your help!
chris
(3,250 Views)
Chris
Have a look at the main menu "Options"->"build options". The last point in
the dialog is named "Display status dialog during build".
Be sure to uncheck this options. It will increase compile time dramaticly.
Stephan
chris schrieb im Newsbeitrag:
39740fe1@newsgroups.ni.com...
> RAM
> chris
(3,250 Views)
But this option is unchecked!!! The debug -exe file is about 18MB!The release
- exe only about 2MB! So i think to generate the 18MB exe file each time
needs much time!(2,30min)
Testing a project is very hard because i need to start and stop the project
often!
Has anyone the same experience with big debug files?
Thanks a lot chris
"Stephan Gerhards" wrote:
>Chris>Have a look at the main menu "Options"->"build options". The last
point in>the dialog is named "Display status dialog during build".>Be sure
to uncheck this options. It will increase compile time dramaticly.>>Stephan>>chris
schrieb im Newsbeitrag:>39740fe1@newsgroups.ni.com...>>>>
I use cvi 5.5! When i want to compile my project>> it
takes a very long
time(up to 2 minutes)! I use a AMD K6 450MHz 128 MB>> RAM>> so I think the
PC is not the Problem!>> Does anyone know some settings to increase Compile-Time!>>
Or is it a generally Problem!>> Thanks for your help!>>>> chris>>
(3,250 Views)
