LabWindows/CVI
CVI 6.0, Build on NT4.0, Install on Win2K
Are there any known problems if a CVI 6.0 application is built on an NT4.0 PC and then subsequently installed on a Win2K PC via the distribution kit?
(This question seems pretty basic, but I couldn't find a similar one while searching the board. Apologies if this is a duplication.)
(2,818 Views)
Hi Scott,
I have not found any known issues with CVI 6.0 Distribution Kits built on Windows NT 4.0 and used for installation on Windows 2000.
I just spent some time with one of our test machines, and was able to successfully build one of the CVI 6.0 examples on NT 4.0 and install it on to Windows 2000 using the Distribution Kit. I did not encounter any issues during any part of the process.
I do not expect you will have any problems with building and installing the distribution kit.
Scott Y.
(2,793 Views)
