LabWindows/CVI
CVI 6.0 : Memory leak in Toolbar ?
Hi all,
I am having a small memory leak with the toolbar instrument in CVI 6.0.
The Program Attached will display the following (on the debug window after closing the main window):
Dynamic Memory Information: Left
Total number of block allocated: 11
Total number of bytes allocated: 440
Dynamic Memory Information: -ToolBar
Total number of block allocated: 2
Total number of bytes allocated: 80
Dynamic Memory Information: -Panel
Where in the last statement I should get 0 block 0 bytes.
Anyone knows how to plug this leak ?
Thanks in advance.
(2,947 Views)
Sorry, I don't have a solution for that, I only can agree. I found out the
same. The leak is also there in the toolbar in CVI 5.5.
Torsten
Farid Bengrid schrieb in im Newsbeitrag:
506500000008000000C9300000-1004225886000@exchange.ni.com...
> Hi all,
> 6.0.
allocated: 80
> Thanks in advance.
(2,947 Views)
