LabWindows/CVI
CVI 7.0 Evaluation Version can't execute sample programs?
Even when I run the sample programs, there's "Entry Point Not Found" error. I downloaded CVI 7.0 Evaluation Version from NI website and installed it without the accompanied CD. Did I miss some part of the installation and cause the above problem?
Echo
(3,548 Views)
I know now. That's because I didn't install the RunTime Engine.
Echo
(3,548 Views)
I was curious how you got in a postiton of not having the Run Time Engine? The evaluation version installs the CVI RunTime Engine always. There is not a way to turn it off in the installer.
I am the installer person for CVI at the moment and am curios as to how this situation occured. Can you please elaborate on how this happened?
Jeff
NI
(3,548 Views)
I was investigating how CVI6.0, CVIRTE7.0, CVI7.0 would cooperate. So I installed CVI6.0, CVIRTE7.0, generated DLL, uninstalled them, then installed CVI7.0 and run the DLL......
Maybe not follow the above sequence. I did such for several times in different sequences. At last after I installed CVI7.0 again, I found it can't even run the sample programs. Then I installed the CVIRTE7.0, the problem solved.
Hope this helps.
Echo
(3,548 Views)
I got it.
The problem is caused by a third party app which installs CVIRTE6.0 in AlwaysOverwrite way.
Echo
(3,548 Views)
