LabWindows/CVI
CVI 7.0 application slows down over time
I have an application in CVI 7.0 that sits in an infinite loop just reading voltages on a custom board over the CAN bus. The application slows down over time and each time it goes through the loop, I see the numbers in "Mem Usage" column under the Windows Task Manager go up by about 4K or 8K in an inconsistent manner. I have gone through my application and made sure that there is no "unfreed" dynamic memory. Also, I have observed this behavior only when there is a step in the loop that requires more than 40% of CPU time. I am running the application on a DELL Poweredge server running Windows2000 Server using NI CVI 7.0 and NI-CAN 2.1.
This is happenning on a delivered system at my customer site and has become a major issue. HEED HELP!
(3,428 Views)
This must be a memory leak of some kind. Post your code and I am sure someone can help you out.
Jamie
(3,395 Views)
Also note that you can use CVIDynamicMemoryInfo() to get information about the amount of dynamic memory that is allocated at a particular point of execution. This could help you track down the problem.
Alex
(3,388 Views)
Thanks Jamie and Alex,
As a matter of fact, I did come across the CVIDynamicMemoryInfo Function and have been able to use it to my advantage. I found a couple of memory leaks in the application and now it doesn't seem to slow down any more. At least over 24 hr testing. How it does over a longer term, only time will tell...fingers crossed...
Sunil.
(3,368 Views)
