LabWindows/CVI
CVI 7.0 local license issue
I am having trouble activating CVI 7.0 with a local license.
I already have CVI 2012 activated on my PC with a site license.
The license manager doesn't "see" the CVI 7.0 installation.
I'm working on a legacy product that requires the CVI 7.0 IDE.
Scott
(3,187 Views)
I would assume that the license manager was invented much later than CVI 7.0 and thus CVI7.0 will not know what to do with the LM and vice verse... If I remember correctly at that time I only had one printed license key.
(3,175 Views)
Anjelica from NI informed me that 1) CVI 7.0 does require the license manager and 2) the license file needed to be "CVI_FDS_PKG_070000.lic" instead of "CVI_FDS_070000.lic" for the license manager to see it.  The latter is what the CVI 7.0 install CD created.  So I renamed the file to the new filename, then in License Manager I ran Options->Install License File and selected the new filename.  Then CVI 7.0 was displayed in the license manager.  After that I just had to activate the license and everything ran fine.
Hope that helps someone else trying to run multiple CVI versions.
Scott
(3,138 Views)
