07-05-2005 10:40 PM
07-06-2005 01:17 PM
No, you can not install just the MSI and have CVI work (it contains many MSI files that work in conjunction). You can browse the CD and click on the setup.exe in the root of the CD.
What it looks like though is that the CD has a scratch or something and that file is corrupt and can not be loaded. What you can try is to copy the entire CD to your hard drive and then run the Setup.exe from there. Also try it on another machine, sometimes you can detect a bad CD-ROM drive by getting these errors only on one machine.
Anyway, if that doesn't work let me know an I will send you an email directly to get you info. That way we can send you a good CD.
Note: if you have the FDS version you can download the Eval from here:
This is the same as the release, the licensing controls whether you are in eval mode or not.
Jeff
NI
07-06-2005 09:40 PM
