CVI 8.0 NI-DAQmx 8.9.5 compatibility?
New laptop, installed CVI 8.0.1 then NI-DAQmx 8.9.5 that came with USB-6211 DAQ. Device runs fine using MAX.
When selecting CVI Tools/Create/Edit DAQmx Tasks... a pop message says "This feature requires NI-DAQmx. Please Install NI-DAQ from the NI Device Drivers CD or check your installation."
NI-DAQmx does appear in the libraries however.
The example program Acq-IntClk compiled, but a couple error message appear when the application is run:
"procedure entry point SetEnableResourceTracking could not be located in cvirte.dll"
"failed to load nicvidu.dll, Check your installation"
If I continue through the errors, the application does seem to work.
Any obvious compatibility or installation issues here?
(3,504 Views)
Accepted by topic author Scott_T
Upgrading CVIRTE to 9.0.1 fixed everything.
(3,481 Views)
