LabWindows/CVI
CVI 8.0 setup error
Dear all:
    I want to setup CVI 8.0 to my colleague's PC, and take errors like accessory pic. Also I want to setup the distributions made by CVI 8.0 in my PC to the same PC, the same error occurs.
   I try several times and several distributions in this PC, also the same error, while OK in other PC.
   Can anyone can tell me how to solve this problem except reinstall the OS? The current OS is XP Profession SP2.
   Thanks very much!
(4,086 Views)
I found a reference to a similar (if not the same) issue on Microsoft's website.  You might want to review these.
http://support.microsoft.com/kb/884538
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=320994&SiteId=1
It also appears that other users have had a similar issue with NI products:
http://forums.ni.com/ni/board/message?board.id=170&message.id=242138
http://forums.ni.com/ni/board/message?board.id=180&message.id=28339
I hope this helps.
Kevin C.
(4,073 Views)
Dear kcoggins :
    Thanks for you great help. But the other NI products problem are all solved by reinstalltion, while I can't install all the while, so I can't refer
to their method.
   Now I am waiting for OS Patch from Microsoft. Any progress, I will tell you.
    Thanks again
帖子被尤文蒂尼在11-20-2007 07:52 PM时编辑过了
(4,031 Views)
