LabWindows/CVI
CVI 9.0 SQL
I'm using CVI 9.0 and the SQL-Toolkit and I receive always the error number -101 from all database functions from the SQL-Toolkit (e.g. DBInit, ...).
Can anyone help me what this error number mean? How can I fix them?
Thank you for your help and
kind regards from Austria
Jürgen
(3,861 Views)
the error 101 can be following reason
http://digital.ni.com/public.nsf/allkb/1FECABA3EA349052862565DF004D5BEF?OpenDocument
http://digital.ni.com/public.nsf/allkb/6ACA5407668D4CEF86256A7E004C68EB?OpenDocument
-101 to -500 toolkit CIN DLL Setup Error. Could not find the functions within the dlls. Could not load the support dll or incorrect version of support dlls.
Best Regards
(3,824 Views)
This Link describes a solution from my colleague
https://forums.ni.com/t5/LabWindows-CVI/Problems-with-SQL-Toolkit-LabWindows-9-0/m-p/838040?requireL...
So repair function in System -> Control Panel -> Software -> National Instruments -> Change/Deinstall -> SQL Toolkit and or CVI entry -> Repair
should solve the problem.
Best Regards
(3,822 Views)
now it works :-).
Thank you very much.
Jürgen
(3,807 Views)
